White 2550 mower engine bog down
Hit pto (blade) and bad. Will mow but just no power. She's 14 yrs. old. Tuchumseh 25 hp v twin. like it is starving for gas. New fuel filter. Took air filter off, which I need, blades, spin freely. Took belt off and engaged pto. not a clue there just engaged, Thanks for any other info or tips
Dave
Some small engines have a soft key on the flywheel that's supposed to shear instead of bending or breaking expensive stuff. Might see if you've messed up the key and it has no power because it's pretty far out of time
Could be running on one cylinder. Pull one plug wire off and use a 1/4" bolt to ground it to the engine. see if it will start. If so and it sounds the same, it is broken. If it willnot start, try the other plug. If it then starts, bingo. Compression check, plug swap etc. Jim
Thanks all. She's gotta go another year. Then the ZTR move. Pricing them. Don't know why the wife keeps looking over my shoulder
