White--4-80-17 backhoe
lenray
This tractor has the Funk Reversomatic --one pedal forward-one pedal reverse. I can't find the oil filter for the Reversomatic for this unit. This tractor would be like the Oliver 1650 Industrial----
Don't know if this will help. Just checked my factory shop manual on the
Fleetline through 3 digit series. It shows the filter for the Reverse-O-Torc to be remotely located, receiving oil under pressure from a fitting on the right side of the housing as the operator views from the seat. From there the oil goes through a heat exchanger and back to the sump.
Thank you Spunky Flat Ron--found the oil filter--it was remote. There are two heat exchangers way up front behind the heavy grill. Both right there together. Working alone I can't tell which one is the heat ehchanger for the reverse-o-matic. The front one or the one behind it...thank you for your help....
