White 5100 need help ASAP
We'll start planting corn yesterday and ran into a big problem. The cage fan started striking the blower housing. So I pulled the thing apart straightened the bugger and stuffed it back in. I spun the thing pretty fast by hand and it rotated smooth and way better balanced than before the problem happened. So through the shroud and oil cooler back on, check again for clearance. Then I turn the pump on and it runs fine for 10 seconds and it starts shaking again. Pulled the thing apart AGAIN and wouldn't you know it, it bent again. What would cause it to bent like that?
