White 6144 Hydraulic issues
RichS
I have a 1996 White 6144 with the 32x32 transmission, while disking the Hydraulic Filter Restriction light came on. All hydraulics worked, 3 pt, remotes, and transmission. Replaced both filters right and left side. After about an hour of running in 70 degree weather, the Hydraulic Filter Restriction light came on again. All hydraulics work, transmission shifts fine. Any ideas, charge sensor?
Do those use the same setup as the 2-135s and what not? If so,I'd do the case drain line test and see how much bypass oil you have.
The 6124-6144 Whites use a Massey 32x32 Dyna 4 transmission and rear end, hydraulic system. It is not like the 2-155 I had prior to the 6144.
