White smoke question
jeffred
I have a BN I got this summer from an estate sale that I'm starting to worry might have head gasket issue. When I changed oil last week it had a slight cream color like there was antifreeze in it. But it was so slight I started looking at exhaust smoke. Every time I start it, it had always given out a small puff of white smoke that quickly disappears. When it runs at idle there is no white smoke, and running it down the road there doesn't seem to be any either. It does give a pretty big puff of white smoke when I move the throttle from idle to full quickly that quickly disappears. Should I be worried about the white smoke? Trying to figure out if I should park it in the back of the shed this winter or up by my shop bench to wrench on it.
do you have anti freeze in the system after setting for some time without starting drain and see if coolant comes out of the pan first that will tell you if theres a problem with coolant leak' The head gasket on that engine can leak into the cycls also usually towards the rear thats what i have found over the yrs. Even had on that the gasket was upside down.
If It has antifreeze in the rad. the "smoke" (steam?) will have a n odd sweet smell. If you pull the plugs and any are really clean that would indicate antifreeze getting into that cyl. too...
