Why so wide
Determined
Why is it I can click on and follow a topic and everything displays normal.
Then once in a while somebody replys to the post and the page is bigger than it just was.
Annoying as all... having to scroll side to side to read the thing.
Am i the only one with this problem?
Is my computer too old?
Do iI need to change a setting on my computer or something?
Glad to hear it's not me.
Not saying my computer is old but if there was a site called Yesterday's Laptop I would likley have joined by now.
Just saw a post on the Restoration and repair section titled;
1959 Ford 841-D
It comes up about two and a half times the width of my screen.
Hi I was reading one like that last night. If I have
had a bad day I just give up reading them. I come
here to relax and maybe help someone in my spare
time.
If I wanted to deal with more BS i'd just go back
out and work more on the days awkward shop job
L.O.l.
Regards Robert
(quoted from post at 21:45:26 06/10/14) No, it's not you,
Usually happens when someone who doesn't know how to size pictures posts a "too large" one.
Allan
That is my observation too Allan.
It's normally a picture. Then the text just wraps at that width.
Hmmm, I just looked at it... and it is wider than my wide screen monitor too. And my computer is only about a year and a half old.
I've only ever seen that before due to someone posting super-sized photos.
Allen, I suspect there's a bunch of us old geezers here who lack the computer saavy to know how to size photos. I sure don't. Feel free to offer a tutorial any time you'd like.
(quoted from post at 23:26:29 06/10/14) I forgot to say that I am reading/posting in Classic view.
es, it happens in [u:fb6430e68d]BOTH Classic & Modern[/u:fb6430e68d]. The diagram is 3176 pixels wide....about 2X one that displays OK.. I almost always post 900 pixels wide unless the picture I'm posting is already smaller.
If someone is going to post pictures here, they shouldn't do it if they don't understand how to compress and resize images. There's rarely a need to post an image more than about 500 pixels wide. I usually make mine 640 pixels wide, just because that's the width of a standard VGA screen, even though I doubt anyone is using VGA these days. Most folks on desktop PCs have display widths of at least 1024 pixels, although much of that is not available in a message post.
While resizing, you should also compress the image by reducing its quality. A small reduction in quality is unnoticeable on a computer screen, but makes the file significantly smaller. Smaller files load faster.
I'll add that you should resize and compress even if you're using a third-party site like photobucket to host your images.
How to do it? Well there are as many different ways to do it as there are photo editing programs. But there's no need to buy high-end software like Photoshop; there are plenty of free alternatives:
GIMP (GNU Image Manipulation Program) is a image-editing package. <a href="http://gimp.org">http://gimp.org</a>
My preferred tool for resizing images is Image Magick, which is a set of command-line utilities for image manipulation. It is available on Windows and Mac OS/X in addition to its native Linux. <a href="http://imagemagick.org/">http://imagemagick.org/</a>
The "convert" utility from Image Magick is used to resize and compress pictures. For example:
This command will take original image "oldfile.jpg", resize it to 1000x750 and reduce its quality from 100 to 70 percent. Looking at one of my own photos, this reduced the image size from 4000x300 (12 megapixels) to 1000x750 (.75 megapixels) and reduced the file size from 4.9 MB to 196 KB.
You should try to resize to an even fraction of the original image size, although it's not essential if you don't know the original size.
(quoted from post at 05:27:15 06/11/14) If someone is going to post pictures here, they shouldn't do it if they don't understand how to compress and resize images. There's rarely a need to post an image more than about 500 pixels wide. I usually make mine 640 pixels wide, just because that's the width of a standard VGA screen, even though I doubt anyone is using VGA these days. Most folks on desktop PCs have display widths of at least 1024 pixels, although much of that is not available in a message post.
GIMP (GNU Image Manipulation Program) is a image-editing package. &lt;a href="http://gimp.org"&gt;http://gimp.org&lt;/a&gt;
My preferred tool for resizing images is Image Magick, which is a set of command-line utilities for image manipulation. It is available on Windows and Mac OS/X in addition to its native Linux. &lt;a href="http://imagemagick.org/"&gt;http://imagemagick.org/&lt;/a&gt;
f using photobucket, it has settings to allow you to select a size for all of your uploads, now &amp; future.
If you can handle posting pictures on this website, you can surely handle resizing them before you upload them:
In Windows, all you do is load the picture in "PAINT" and click on the "RESIZE" button.
Select "pixels" and make sure "Maintain aspect ratio" is checked.
Change width to "640" and hit OK.
Use "Save As.." to save the picture if you want to keep the original high-resolution version.
>If using photobucket, it has settings to allow you to select a size for all of your uploads, now & future.
I prefer to do it upfront on my client. That way I can optimize the size and compression for the particular picture. Plus save time and bandwidth uploading huge files.
Just saying that there is a simple method for those that don't want to or maybe can't do it on their own or don't want to think about it each time. To each his own. :D
I have never had to resize a photo before I posted it. I post all of my pictures directly from my computer files.
I thought I read several months ago where this site had software that only allowed pictures up to a predetermind size, and would resize the pictures to fit the post.
Correct me if I am wrong.
YTSupport
10-18-2013 18:09:43
72.171.16.247
Re: Post size way too wide??? in reply to JD Seller, 10-18-2013 18:02:22
We try to shrink the photos on the fly when people post them too large, but if I recall, I only got that done on Classic. Modern has a problem doing that in that it's bbcode and not straight html. That made it error prone when I attempted it. It needs to be fixed though, people don't realize the resolution size when the put up a picture. I'll start looking it over again.
If you upload on our photo server, it will automatically make it web ready. I took the old limitation off on the size of the incoming folder, so even the large ones should post now, they get shrunk anyway.
Let me know which post it was you were seeing that, I'd like to see why the other persons photos are distorting yours just so I know how to change the program.
