wico xb distributor spark issues
I have a wico distributor on my 50 and i have no spark. if i take the cap off, and flick the points there is a spark though not very strong. does this sound like a coil problem? I would really appreciate an y help.
Andrew
Andrew:
The points are breaking the 12 volt path on the primary side of the coil, so the spark you see there is only 12 v, not the spark that you would expect on the spark plug side, and yes, those XB distributors were notorious for coil failures.
so then you are saying it is probebly the coil? can I test this, or wire up a temporary external coil? the tractor was running great when parked 15 years ago. would the coil go bad from sitting?
thanks for the reply!
Andrew
It could, or it could be corrosion at one of the terminals. Sometimes an improper jump start can ruin them. Or a switch left on. If you know what you are doing, you can wire in an external coil, but it's a little tight to do it without being tempted to cut an extra hole for the wires....
Andrew,
I would try new points and condenser first, at least cleaning your points.
When I bought my 51 B it had an external coil wired up to the mag, making it work like a distributor. The previous owner had bored a hole in the cap for the high tension lead from the coil. Actually worked just fine.
I bought an XB distributor for it, and purchased a new coil and bushings from Glen in Texas. He no longer seems to be in the business. He did send me a number of PDF"s about the XB distributor which were very useful. I could email you copies if you like. (assuming I can find them)
I eventually rebuilt the magneto and now have that on the tractor. It is much more reliable than the XB distributor.
So a few solutions would be:
Clean the point, get new points and condensor
Install External coil
Buy a new coil for the XB
Get a magneto
Get a delco distributor - much more robust than the XB
Good luck,
Kurt
Those Wico's have an internal ballast (a small wirewound resistor lookin unit) there on the inside of that phenolic plastic lookin block where the wiring stud is, they have been known to go bad. They are very low ohms, less then 1 I believe or not much over.
Far as I know ALLLLLL those XB's use 6 volts so on a 12 volt tractor in addition to that internal ballast mentioned above there should be an external ballast BETWEEN THE IGN SWITCH AND WICO INPUT STUD to reduce the 12 battery volts down to 6. You might stick a volt meter on the Wico input stud/terminal and with ignition on and points closed see if you get around 5 to 7 volts?? If its 12 and they are allllllll 6 volts as I think (NO warranty on that mind you) THE COIL WILL RUN HOT AND EVENTUALLY BURN UP. I EITHER picked that up from Duane of Glen or read it, but Im fairly sure alll Wico XB's operate at 6 volts?????????
FIRST Id try what the other good gents mentioned, check clean and gap the poinst n try her. So often the poinst are the problem.
If you remove the wire on the input stud its possible to test the coils low voltage primary winding to see if its BAD...... A good ohmmeter on the low ohms Rx1 scale placed across case ground and the lil points terminal should read near 0 ohms when points closed but 0.5 to maybe 1.0 ohms when opened BECAUSE THAT REPRESENTS THE COILS LOW VOLTAGE PRIMARY WINDING. If thats an open circuit the coils primary is burned open IE ITS BADDDDDDDD........ The coils HV secondary is between the HV tower output and case ground and it should be like 5k to 10k ohms, again if its open its badddddddd
HOWEVER a coil can pass those low voltage primary and secondary resistance checks AND STILL BE BAD because they break down at HV under temperature. The tests above ONLY show if its BAD not if its GOOD
This may help some or may make matters worse!! Its NOT hard to test the primary and secondary of the coil for a bad/open so try cleaning the points and check the voltage on the input stud when points are closed and check that internal resistor and you may ?? diagnose the problem
Let us know what you find
John T
I had the same problem after I left my key on and solved it by cleaning the points. Great spark as soon as cleaned them with fine emery cloth
Ron
well i disassembled and cleaned the distributor, put it back together and and got a few sparks from the spark plugs then it slowly stopped sparking. I might have got 14 sparks from the plug. So I bought new points, now when I flick the points to see the spark jump, there is basically no spark jumping at the points. there is however a spark jumping from the coil steel body to the coil winding kind of where the side bar comes beside the coil just before it goes into the coil winding. aslo at the back of the coil steel bar where there is a slit in the steel bar, it is jumping back to the coil winding, when the points are flicked. wierd! i thought maybe the coil or points were not gounded well, sanded the base, made no difference. any idea. the main power post widing on the distributor get hot to, thanks for your help!
