will a 619 engine fit?
markie
Hi,
My question is, will a 619 AE 03 engine just right bolt in a 6030? Or do I have to make some changes to the pully, radiator, fan, shroud, exaust and sheet metal?
Please help,
With kind regards,
Mark Vaessen
Yes it will bolt right up, the only part that may not match up is where the air cleaner mounts on the head, you will need to make a bracket to let that hook up, nothing tricky,
Thank you Tim,
So you say, that everthing will fit, like the waterpump, the pipe from the exaust to the muffler, the turbo, etc. Except the bracket of the air cleaner.
Do you also know if an aftercooler from a 531 will fit and work on a 619?
With kind regards, Mark Vaessen
