I have just finished putting the engine back together after a rebore .90 I can get the engine to run has good compression but when I take the choke off the engine sputters and dies. I rebuilt the carb and reset the idle and the load needle as directed in the sevice manual still no luck. When I reinstalled the head I set the gap on the valves to ,22 as discussed in a previous forum could this still need additional adjusment. Also is there a trick to putting the shifter lever back in I get everything back in order but cannot get the shift lever to move back and borth between the gear stacks. when the clutch is engaged the flywheel will not turn unless I push extremely hard on the clutch lever.
any help would be greatly appreciated
Dean
Dean
