wiring a gm alt.
36 A
What is the easyist way to wire a gm alernator.I dont care if its just a kill swich so it wont kill battery when off and guage i just want it to work to charge a battery.Its on a line shaft and right next to the battery.i know it sounds odd but it just needs to work for a short time.
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/424IH/Alternator%20Stuff/Delco10SIManualExcite.jpg">
Make the switch a push button type. If using on a machine with magneto ignition and a engine that makes oil pressure use a HOBB switch. It is only neded to flash the alternator to make it work. If this is not used on an engine with battery ignition and an ignition switch you do not need the diode or the resistor.
I have a set-up like this on an old 5 HP vertical shaft tiller frame. Make a handy portable battery charger.
Kent
