wiring diagram needed
Ed Junior
I recently purchased a wiring diagram from www.oemtractorparts.com they sent a diagram and it isn't readable any one have a larger diagram for a stage one super h? thanks
For a 6 volt you need diagram #2 on the link Janicholson posted, unless you have a mag in which case you might have to combine it with parts of diagram #4, I think.
Zach
I have for leads at the generator one goes to the f other to the a on the generator where does the other two go?
The Bat lead goes to the load side of the Amp gauge. Should be the only thing there. 10 gauge wire
The L terminal hooks to the Light fuse and from there to the ignition 10 gauge wire as well (only if it has battery ign., if mag no connect) Jim
(quoted from post at 20:30:05 01/07/13) I have for leads at the generator one goes to the f other to the a on the generator where does the other two go?
Then four wires should be at the regulator. One from the light switch, one from the ammeter, and two from the generator.
