Wiring diagram needed
(quoted from post at 10:06:23 09/07/12) Hello, I'm looking for a wire Diagram for a Ford 800 with a 12 volt system.. Can anybody help me with this ?
ame answer as yesterday: "give us more info on the tractor specifics."
If it's an 800, then it came from the factory with a 6 volt system. It depends on how it was converted to 12 volts as to what schematic might apply. Does it have an alternator or a generator? If it has an alternator, how many wire connections are on the back. Does it have an external voltage regulator? Without this kind of information we can't help you.
(quoted from post at 15:10:23 09/07/12) single wire
f single with Delco 10-SI, then JohninLA has you covered:
(quoted from post at 16:43:04 09/07/12) Thank you !!! Thank You !! This is just what I Need !!!
hen I posted that diagram, I didn't really look at it, but have now & I personally would not wire mine with ammeter in that location. It will work & ammeter location is a matter of personal preference, but I like the old-school "net" metering where it shows the net of into/out of battery, whereas the posted will never show a discharge (out of battery), rather only alternator charge current into battery. I would change it as follows for myself:
Later: cleaned up it looks like this
