Wiring Diagram
"What is the wiring diagram from the requlator to the generator?"
That should be pretty simple... "A" on generator to "A" (or "ARM") on the VR, "F" on the generator to "F" ("FLD") on the VR.
A wire from the dashboard "idiot light" will also share the "ARM" terminal at the regulator.
The "BATT" terminal on the regulator connects to the battery cable terminal at the starter solenoid.
Thank You.....on the bottom of the regulator I have a black, red and blue wire. where do these wires go? Sorry for not knowing?
Can't help you on the wireing, but I had a 2010 once and it wouldn't run without the choke out and burned points often. Turned out to be a bad switch. Hope you don't get that problem.
KEH
I don't know the color code, off hand. Check and see if the colors of two of the wires match at the regulator and VR and go from there.
(Just to clarify... this IS a 2010, using a GENERATOR, correct?"
