Wiring for farmall A
Farmall-H
Hey guys,
What gauge wire is used for the kill switch to ground out the magneto on my A. Or which gauge do you recommend? Thanks as always!
-Cole
A battery powered coil ignition only draws like 4 amps and a Mag (subject to mags specs and RPM) is probably even less, so 20 or less gauge would likely work fine, although Id still want a big enough stranded wire just for its strength and flexibility. Stick a 16 gauge on if you like it will for darn sure have plentyyyyyyyy of ampacity but also be fairly strong.
John T
