douglaslee-HT
Aaron: I got a replace ignition switch from Hoye for my FX 30, 3 cylinder diesel. The defective ignition switch has 6 wires; The terminals are marked as follows: E (black wire with yellow stripe) which leads to a 4 prong relay switch/box, B (white wire with red stripe) which leads to the battery positive cable, C1 (black wire with white stripe) which leads to the fuse block, C2 (black wire with red stripe) which leads to the glow plugs, BR1 (black wire) which leads to 8 prong relay switch/box, BR2 (white wire with black stripe) which leads to the starter solenoid.
The ignition switch from Hoye has the terminals marked as followed: ACC, BR (to fuse box), R1(glow plug), R2(glow plug), B (to battery), and C (to starter). Except for the battery, fuse, glow plug and starter the diagram available does not indicate what terminal leads on the new switch would be appropriate for black wire with yellow stripe and black wire as I described in the first paragraph Would these wires be attached to the Hoye ignition switch terminal marked as ACC? Also, does it make any difference as to which glow plug terminal, either R1 or R2, that is used for the one glow plug wire on my tractor? <E>:?:</E>
