wiring harness
Here's where I got mine.
http://www.wiringharnesses.com/catalog.pdf
you can see part of it in the picture. the large loom at the bottom of the switchbox was added by me. Everything made up perfectly. The catalog lists your tractor. I have no afiliation with the company. And also, they sent it pronto.
HTH
Best regards
Patrick
'49M
I used a Brillman harness on both of my restorations. No better quality in my opinion. All came with step by step instructions and evrything labeled. They also sell high quality American made voltage regulators.
http://brillman.com/store/b3024-115-farmall-560-gas-wire-harness.html
Have yet to buy a harness for my '48 H, but from what I have seen and heard, Brillman has good stuff. It is also nice to know that documentation is provided.
Question: Does the above mentioned documentation include the correct and original routing for the wires? There have been some repairs done to my tractor over the years, and I am convinced that the current placement of some wiring is incorrect, and that some of the clips are missing.
Yes, Brillman is good too. I've gotten stuff from them before. But when i did some price comparisons, I chose the other.
Best regards
Patrick
'49M
(quoted from post at 00:53:49 01/12/14)
Should've seen mine when I first got it. (tractor that is) It was like a bowl of spaghetti. I was amazed that it ran at all.
Well, anyway. Each wire is color coded and lettered or numbered at each end connector. Also included is a list of the same wires telling you exactly what appliance to connect each terminal too. The routing was not hard to figure out. That's how mine came. Simple enough on an 'M' with mag ignition and cutout, not sure about the others.
HTH
Patrick
'49M
(quoted from post at 08:57:32 01/12/14)
Best regards
Patrick
'49M
Does these harnesses employ the original color codes and cloth braiding? Their prices are certainly reasonable.
Yes, but not sure about the originals. The braiding is there which is what is used for the color coding process. Several different color combinations. Not confusing at all. Easy to understand instructions.
HTH & best regards.
Patrick
'49M
