Wiring help with JD B/L
DYNAH8TR
Hello, this is the place I come anytime I am stumped or need information I cannot find. Today my 1984 (someone called it an 81) John Deere backhoe loader had a dead new set of JD batteries was dead. I jumped it with my 200amp start (scares me, seems to have too many amps!)and I saw a glow. The glow was a fire at the alternator. I can get an alternator but it looks like where it smoked was inside and also the large BATT terminal. I see 2 male plugs marked 1R and F2. I have no wiring diagram but I avoided a disaster. Any help is appreciated; Thank you!
I'm sorry it is a 500C model. Thank you in advance for any help!
I have a big ring for the "BAT" and looks like 2 female connectors. Sorry, I am just antsy, that fire could have cost me 10K. Thank you......
You sure you had the battery polarity correct when you hooked them up,the main cable from the starter motor to the positive terminal of one battery,from the negative terminal of that battery to the positive terminal of the second battery,from the negative terminal to ground,connected last,it is crucial to have the polarity right as one tip of the lead with the power going in the wrong direction will blow the rectifier bridge in the alternator rendering it useless, the two light wires on the alternator,one will be for the alternator warning light and the other is usually for the voltage sensor.
AJ
Thank you. I'd love to have a wiring diagram. I hooked up a plain "one wire" alternator and it now runs and starts perfect. The rear lights are on, but no others. Most didn't work before; I'll check it out. Thank you for at least replying.
Sorry I don't a wiring diagram,have you checked the switch that controls the back lights,it is either not opening to shut the lights off or there is a wiring issue,there is loads of those JD's about someone will have a manual and give you a scan,there is a small diagram in the on-line parts catalog at the link below,go to the link, type in your machine in the search box,when your mackine comes up use the A to Z index, click W and find the lights,when you find the drawing it's small.top pf the panel click on Print selector, from the menu click on illustration and a bigger drawing will appear,click on the middle box top right corner to expand the drawing.
AJ
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Thank you.
Originally it had a generator and external voltage regulator. Then a late model GM starter was in there with the 2 terminals. The battery was dead 0 volts, so the amperage was super high. I tried my 200Amp charger/stater and the diode pack melted causing the fire. I put it back together with a 1 wire alternator and everything seems to work. I need to chase down why my 2 front lights are dead....They were dead prior.
