Wiring question
Ray in CT
Does anybody have a suggestions on where I can get a complete 12 volt wiring harness for my 1944 M. It is already converted but very sloppy, When I finish on the restore I want a new wiring harness. thanks
There may be no such thing. A proper 6 volt harness is available from several sources. They are the same as 12volt. The wiring makes no difference between 6 and 12v. If you have an alternator, the wiring for that will be in adition to the wiring supplied for the generator. The 10 gauge wire originally intended for the Bat terminal on the VR can be used for the Alt main output wire, other than that the 6v wires are fine.
Jim
bob M believable diagrams
