Wisconsin 2-cyl engine
Anonymous-0
My woodsplitter engine seized while running but would turn when cooled off. I took the base off and I think the problem is the oil pump plus now a rod bearing. My book shows the pump in the corner of the crankcase but mine is centered on one side. My parts engine has the pump in the corner too. Does anyone know which is the later model? TIA
Which engine?? The TE, TED, TF, TFD, etc. have the oil pump in the corner. The TH or THD has the pump in middle.
None of them have pressure oiling - just spray. Older engines have babbit bearings, and later have shell-bearings.
