ryanwheelock
Just got a spare Wisconsin VF4 engine from someone, was gonna keep it as a back up for the Lincoln Welder driven by a Wisconsin engine that I've been working on. My question is it only has about 30-35psi of compression on each cylinder, some less. Think it should be up around 80-90psi, manual I have dont give them specs.
Is there a way to test if its loosing it out the valves or out the rings. I think i remember something about putting oil down each cylinder to figure it out??? Otherwise I'll pull the heads and check it out.
When cranking the engine it kinda back fires threw the intake so makes me think its a valve issue.
Any input would help
Ryan in Northern Michigan
