wisconsin vh4d
Railroad
Hello all. I have a Wisconsin VH4D on a Vermeer stump grinder and after 35 yrs the engine has finally died. I am trying to determine which direction to go from here. The decision is between buying a new engine or rebuilding this original engine. I retired last year form being a mechanic for forty years; however, I never did engine work. I did nearly all else but not engine or transmission overhaul. I know I can take it apart and reassemble it but as far as proper ways to rebuild,etc- I don't know these details. I'm asking for input from those that may have some ideas?advice on the subject. Thanks.
Had a Wesconson on an irrigation pump. Great engine, We let the wisconson man do the internal repairs. Parts availablity would be questionable today I'm sure.
You say it died, as in...
Low compression and high oil consumption?
If so, it possibly could be gone through, a hone job, rings, valve job. That would buy several more years, not as good as new but a practical approach.
Locked up, knocking, broken internally?
Chances are it is not economically feasible to repair it.
Nothing to loose by opening it up and looking. They are tough and forgiving. It's your motor, not like you have to warranty your work.
Let us know what you find, get some parts prices and availability.
Might look into a Predator engine.
Id exactly like to know how it died before I answer, but I guess Ill answer before. Like Tom said, parts are available, or at least they were 18 months ago. Not an answer a lot of people want to hear, but if you are patient, good stuff on eBay is available also.
Not sure. I have no trouble tearing engine down, put back together. I don't have the equipment to turn cranks, bore blocks, and grind valves. So I have to farm that stuff out. So, basically I need help from a good machine shop even if I do overhaul myself. You might find yourself in the same boat if you decide to do so.
In the late 80s, my grandfather bought a dozen from a Navy auction. None ran, but all were basically complete. We were able to make 6 run without too much work. We were able to sell them at the time for between $400 and $900 depending on the features (transmission, clutch, starter). I dont remember needing needing any special tools other than getting the big flywheel nut off. Those are on pretty tight.
many swathers used that engine back in the 70's and 80's. lots got parked not because the engines were bad. but its just to find one now. i sold mine a few years ago for 400.00 as a guy wanted it for his bobcat. versatile , cockshutt and hesston used them maybe more companys. just saying it might be possible to find a cheap engine.
I have several of these engines in tobacco harvesters and Hahn hiboy sprayers. They are definitely tough and easy to repair. On the last one I had rebuilt was in 2019 and major parts were available. It costed just north of $ 3500 parts and labor to have it bored and built first class. The early ones had poured rod bearings ($$$$) as where the later ones had replaceable shell inserts. The intake gasket set for some reason has been hard to obtain this year. Other than that, parts have been fairly easy to get if you know where to look. Not sure what you mean by it died, but I've had several head gaskets blow on ones that are ran hard and wide open all day in extreme heat and I'd thought it was trashed. Got new gaskets in them and head planed and was good to go. If it's burning a hole through a head, it's time to rebuild due to excessive oil burning.
I have one that also came from the Navy with the spark plug wires in like tubes. We took it off of a baler 35 years ago and it has
been in my shop ever since. I just don't want to get rid of it...
I rebuilt a TJD, similar two cylinder. Not hard. Cranks run on tapered rollers so usually not a problem unless they were run without oil. I have an extra set of +.020 rings if that would help with parts.
Thanks for all replies. IT died=this means it has been using a good bit of oil recently and now has a knocking or loud clicking noise internally.
I do see these Repower kits with a Kohlerkit as a direct fit for my application. Their replacement is 37 hp instead of 30 ;however, after 35 years of excellent service I have trouble believing that leaving the Wisconsin behind would be a good idea. I wouldn't mind tearing it down and carrying heads,block,crank, or whatever to a machine shop to have necessary work done. Then I would reassemble and reinstall. I'd just need to find a shop to do the machine work. I hate to lose this engine as it has give excellent service in a very harsh environment.
This current situation happened this way: My partner called me to tell me the machine quit on him and would not run. I've always done all repairs on machine. I get to his place and find the rotor in distributor not spinning because the distributor has raised up out of it's position enough to cease making contact with it's mating gear! The hold down bracket was bent upward severely and the hold down bolt was tight. I found the gear which contacts the distributor gear to be in pretty rough shape. I replaced it and cranked the machine up. the engine noise has me strongly believing this engine has done it's final job. Thanks again for all replies.
