wobbly front wheels
Sam Beatty
I use my 48 VAC for everything I do around my house. I was going down the paved road in fourth gear full throttle and my front wheels started to wobble and shake. How can I stop this or fix it?
Hi Sam
You pretty much have to go through the process of finding out what is wore out. It could be wheel bearings, tie rod ends or the steering gear box.
Tom
Sam, Tom is correct, you need to find out waht is wore. For earlier model VA series tractors, I have had several that "wobbled". Generally speaking the worm gear in the stearing box is wore and needs to be tightened. This entails removing the gas tank and the steering box. It is rather a simple job though. I do not have any experience with later models, however I believe they have adjustment on the very front of the tractor. Hope this helps.
I am working on a '48 VAC also.Within the last week I removed the radiator,pedestal,wheels,front bolster ,vertical spindle and wheels.At the top end of the vertical spindle,just under the radiator, there is a bushing in the pedestal that the spindle goes through. This bushing is worn and also the spindle,which gives a lot of movement in the top end of the spindle. I had already gone through the steering sector gear box and found it to be fairly free of wear and was begining to wonder where all the slack was coming from until I found the worn bushing. This could be another place to look for the cause of your wobbly wheels.
