coryeneks
hey yall its me again 48 8n ford ran last week when i parked it now it wont start ..i cleaned out fuel buble now what help thanks.....
I"m assuming it turns over but won"t run. I"m also assuming that when you parked it last week you DID turn off the ignition. If you didn"t, you probably have a burned-out coil and need new points as well.
First, you need to make sure you have fuel in the carb bowl. It"s easy - remove the plug from the bottom of the bowl. Catch the fuel in a can, jar, etc. Let it run until about a quart has come out. If you get a quart with a good steady flow, then fuel probably isn"t your problem.
If you don"t get a quart with good flow, and you have fuel in the tank and haven"t forgotten to turn on the fuel shutoff valve, try loosening the gas cap. If that gives you flow, you have a clogged vent producing a vacuum in the tank, and the easiest way to deal with that is to drill a small hole in the gas cap.
If that doesn"t do it, you have a clogged fuel screen. There are three -- one is a cylindrical thing inside the tank on top of the sediment bowl. The second is a flat screen in the top of the sediment bowl"s housing. The third is inside the elbow that connects the fuel line to the carb. Clean them and see if that gives you flow.
Now, if you have fuel in the carb but it still won"t start, get a 3-foot piece of wire (# 14 or #16) with alligator clips on each end. This should be a standard part of your tool kit, by the way. Clip one end to the terminal on top of the coil if it"s a square-can, or where the wire from the dash connects to the coil if it"s a side-mount. Clip the other end to the post of the battery that isn"t grounded. This may not be the one you think - check to make sure.
If it starts now, you have a failed part in the ignition circuit.
The most common is the ignition switch. It"s referred to on this Forum as "the weak sister."
The other part that could have failed is the resistor, but that"s a bit less likely.
Of course there could be a loose or damaged wire.
Using the wire with clips, try to "jump out" each part, and see which one makes it run.
If jumping from the battery to the coil doesn"t do the trick, there are several things to inspect.
Are the points opening and closing?
Is the coil burned out?
Etc., etc.
If you have tried these things with no success, post back and tell us what you"ve tried and we"ll take it from there. Be sure to include whether it"s a front- or side-mount distributor, and whether it"s a 6- or 12-volt arrangement.
Cory......what Peter sez.....and here is a cheap dollar fix. Ignition points gitt invisible corrosion between the points and won't sparkle sparkies. So slip a dollar bill between the points and "polish" them. Iff'n yer really cheap, a torn strip of heavy brown paper grocery sack will also work. Resist the temptation to "file" yer points. Iff'n you do, you will really muck'up the points and will be replacing them toute-sweete. New points $20 (cheap) They are also known to slip and close and no sparkies.
You do know ittza 2-bolt, 15-min job to remove yer frontmount distributor and change yer points on the kitchen table, don't you??? .....Dell, yer self-appointed sparkie-meister
