(quoted from post at 13:59:50 09/25/15) Which outlet under the seat is pressure out and return in. Want to hook up a wood splitter with two hoses. Need to know the in and out to put the lines on to. Thanks for any information. TEA20 Ferguson tractor. 1951. Noel
(quoted from post at 08:39:53 09/29/15)
Best solution I have seen as far as powering log splitters with a TEA is to use the pto to drive a separate pump .
A pump run directly from the pto and operating a conventional hydraulic splitter will amaze you in its efficiency . You could make one easily enough out of a commercial one with a blown engine and a prop shaft . A simple three point linkage frame will allow you to raise it to any height you want and the piston speed can be controlled by engine rpm .
