Woods Belly Mower
Stan(PA)
I have a Woods L59 Belly Mower that was on my 1951 Massey Pony, and I want to install it on my 1946 Farmall A. The farmall currently has an International 5 foot belly mower (C-3?) on it, with a Woods Hand Lift. The Int. deck doesn't cut nearly as well as the Woods, so I want to change it. Anyway, I'm wondering if anyone knows exactly which parts I will have to buy, and how expensive? If anyone has used parts to make this work, feel free to contact me with a price.
Thanks,
stan
Woods should have all the parts you need. They might want you to go through a dealer though. Get on their website for contact info. They still make those mowers for vintage tractors with Farmall, John Deere, Allis and Ford being the most popular.
Roy, I wish you were close too! I found out, through a Woods dealer, that it would cost me $1000 for the parts to make the change! Guess that old International mower will have to do for now...
I found certian parts they don't make for some of the vintage IH tractors. My dad had a L59 mower on his Farmall A and we wanted to put it under his Farmall H and certian mounting brackets were not available any more. I do remember the prices they want for the parts were out landish. We could of bought a good used mower with the correct brackets instead of switching the mower from one tractor to the other. Their parts book had the prices in it. It must of been an older book I guess.
Woods usually always wrote the part numbers on the brackets with a marker so if any one has one on their A they may be able to give you the part numbers that you'll need.
take both decks to a local welding shop and have them take a look. I'm talking about a small shop that you can tell has experience in fabrication not just a weld two pieces together and follow a pattern. If you see alot of old equipment being repaired that is the one you need. they should be able to modify the one to fit or make brackets. May need the tractor to fit properly. Good luck I would do it for the old deck so I could make it fit mine.
