Woods mower
Russ from MN
Location
Bemidji MN
I am trying to get one of the arbor assembies apart, once removing the roll pin in the top sleve shoudnt it press out the bottom? Thanks in advace, Russ
Are you talking about the blade spindle assembly?
If so they are only a little over a $100 dollars. I've replaced quite a few of them on woods belly mowers, such as the L59, L306 etc.
you get the shaft with bearings and housing already assembled. Just bolt it to the deck and install your blade then you're ready to go. Can't beat it. Don't waste your time trying to take it apart.
Thanks, got it apart, but not without breaking the flange on the housing, it may of been cracked before. There was a good drawing on Woods website and it pressed apart like I thought, just harder because of the roll pin driven only part way thru, I need a complete assy. anyhow because the shaft is bent on this one. Thanks.
