(quoted from post at 11:40:04 03/05/19) Your tractor, your $$$, your choices. You asked so IMHO, I'd would not use any windshield washer fluid or any anti-freeze. Why not? Both are now water diluted per the EPA. Water freezes and if leaking out of tubes, can and will create oxidation (rust). The first signs of leaking usually appears around the valve stem but it may have done significant damage by then. In addition, if you opt to buy the used stuff sold at radiator shops, you don't know what you are getting -they dump all the old used stuff in one container/55 gallon drum. I'm a huge supporter of beet juice, trade name 'Rim Guard'. I've been using it since the mid-1990's and never have had any problems. I'm on my second set of tires and the Firestone AG Tire Center simply drained and reused it. There are 27 gallons in each tire. Some say the stuff is too expensive but to me worth every dime. As I said, I've had the same stuff in them for 25 years. If you had Ca Chl in them, best to invest in new tubes no matter what you choose. I also suggest you haul the tractor to a good tire center and let them do all the grunt work. They have all the right skilled employees and equipment for the job. Leave tier mounted -it's easier for them and saves you mucking up your back and knuckles. It's well worth the price to pay in my humble opinion.
Tim Daley(MI)
ye bye :lol:(quoted from post at 12:30:12 03/05/19) Again as I sad the manual says 32 gals and yes it will hold that. Shoot the 13.9X28 holds 36 gal of fluid and that is what I have in my tire. One has to do thing the correct way to have 32 gals in like have it up on jacks etc. I'm done with you and this forum NEVER AGAIN
es, a sticky mess. Heaviest per unit volume is CaCl & water (5%) , next lighter is RimGuard, and lightest is water.(quoted from post at 14:10:37 03/05/19) Plain water is inexpensive. Adding a little anti-freeze is also inexpensive.
It sounds like the advantages of the beet juice are 1) it is non-corrosive and 2) it adds ~24% more weight per gallon.
I just sent them a request to find a local dealer, so I can get a price.
The question that comes to mind is, if it leaks out is it a sticky mess? With my luck I'd get a leak and every mouse in the county would come over for supper.... :lol:
Thanks. That seals it for me - no beet juice here. Augmented water should suit my needs.Yes, a sticky mess. Heaviest per unit volume is CaCl & water (5%) , next lighter is RimGuard, and lightest is water.
(quoted from post at 15:04:04 03/05/19)Thanks. That seals it for me - no beet juice here. Augmented water should suit my needs.Yes, a sticky mess. Heaviest per unit volume is CaCl & water (5%) , next lighter is RimGuard, and lightest is water.
The ol' girl came with CaCl in the rear tires and it was a mess. The rims were rotten, valve stems rotten, salt water leaking all over the place. Fortunately I needed tires, too, so got the complete assemblies.
have tractors with CaCl in the tube tires and they were like that when I got them. Both have rusty rims, one was so bad that I fabricated a new piece to weld into the rusted thru area. The other newer tractor just shows rust without the rust thru. My opinion is that the primary cause is that people don't fix a small seeping kind of leak. If only air, they would add air every once in a great while when tire low. Bad plan with CaCl, where the seep is salting the rim over a long period of time. Tractors did keep on keeping on for around 50 years without rim repair on one and the rusty-only one is going on ~42 years without repair so far. I don't see a rust problem with the stuff, since as long as tubes and valves are in good shape, it is all contained inside the tube, not in contact with metal rim.(quoted from post at 15:53:06 03/05/19)(quoted from post at 15:04:04 03/05/19)Thanks. That seals it for me - no beet juice here. Augmented water should suit my needs.Yes, a sticky mess. Heaviest per unit volume is CaCl & water (5%) , next lighter is RimGuard, and lightest is water.
I hate these kinds of anecdotal statements but I am going to make one:
I have had CaCl in the [b:91e10e4998][u:91e10e4998]tubeless[/u:91e10e4998][/b:91e10e4998] tires on my Kubota for 25+ years. Not the first sign of rust through inside or out. Perhaps it is better surface coatings on the rims or a better formulated steel. Or maybe I just need to wait another 40 years :roll:
TOH
I have had CaCl in the [b:cbb00ad619][u:cbb00ad619]tubeless[/u:cbb00ad619][/b:cbb00ad619] tires on my Kubota for 25+ years. Not the first sign of rust through inside or out. Perhaps it is better surface coatings on the rims or a better formulated steel.
Both of you are spot on. Surface preparation and paying attention to details are clearly the key to longevity with CaCl.My opinion is that the primary cause is that people don't fix a small seeping kind of leak.
:lol:This is an interesting conversation, so I though I'd chime in and
be a smart Alec. I don't add any liquid to my wheels, I add it to
the tires and/or tubes.![]()
