wow !!! check out this tiny motor
jennifer408
saw this in the fox news:
http://www.foxnews.com/leisure/2015/02/10/miniature-w-32-engine-is-mind-blowing/?intcmp=obmod_ffo&intcmp=obnetwork
[/code]http://www.foxnews.com/leisure/2015/02/10/miniature-w-32-engine-is-mind-blowing/?intcmp=obmod_ffo&intcmp=obnetwork[code:1:b5b8c36c2e][url]http://www.foxnews.com/leisure/2015/02/10/miniature-w-32-engine-is-mind-blowing/?intcmp=obmod_ffo&intcmp=obnetwork[url][/url][/code:1:b5b8c36c2e]
It just runs on compressed air.There are some miniature v8s built that run on fuel spark ignition,even blowers.
Jennifer do you use modern or classic???
In modern you just list your web address. Then highlight the address, and then click the URL button on the upper right side above where you list your text.
The link will then be highlighted in your post.
IF you use Classic you just put the web address in the "Optional Link URL" box right under where you type your text. Then enter your link's title in the next box down. When you preview your post the link title will be highlighted.
Yes it is neat but not a running engine. Out at the rough and tumble show in pennsylvania there were a couple of guys with V-8 engines and they RAN. They were maybe 1/3 larger than this one and sounded so cool!! Another thing is the little hit and miss engines that are this size and run. Like fire fly class or some such. They make like a little snick snick sound when they fire.
(quoted from post at 21:37:03 02/12/15) Jennifer do you use modern or classic???
i use modern: testing
http://www.foxnews.com/leisure/2015...lowing/?intcmp=obmod_ffo&intcmp=obnetwork
thanks, how can i put a title on it instead of an http ?
How about 18 cylinders?
Introduction
https://www.google.com.au/search?q=napier+deltic&newwindow=1&tbm=isch&imgil=2gWnNnWo4vbrbM%253A%253B5I-NlQ6O5KWCMM%253Bhttp%25253A%25252F%25252Fwww.external_link.com%25252Fshowthread.php%25253Ft%2525253D12320&source=iu&pf=m&fir=2gWnNnWo4vbrbM%253A%252C5I-NlQ6O5KWCMM%252C_&usg=__fvGy5Ju2PSqmowj8FKcP7xCpmbw%3D&biw=1234&bih=805
And the model
http://www.craftsmanshipmuseum.com/Tomlinson.htm
When you have your cursor over the little box that says [u:7269de38d3]URL[/u:7269de38d3] you will notice some text that appears just above the response box. It shows how a normal URL link will appear OR that last part shows how to make the changes for your own text to appear. Basically involves adding an = sign and moving a bracket.
Now can someone tell me how to embed YouTube videos so the video appears instead of a link?
Really neat - thanks for posting.
Loved the end where it showed it being put
together. The tiny pistons were awesome - would
love to have one, just for a conversation piece.
