I've got a WR-9 that has a loose ring gear. You can move it around with your fingers with the starter removed - I'm pretty sure that it has a break in it too (Is it supposed to have a split to be able to install it?). I've been told that you can access the flywheel by removing the large plate above it, but I don't see how I would be able to do anything with it without removing the engine. Also, if I need a new ring gear, where could I get one?
I've had this project on the back burner (with a lot of other projects) for a while, but I'd like to start working on it pretty soon.
Thanks in advance for any response.
