Fritz Maurer
If the Panzers froze stiff in the winter cold, how did the Russians get their T34 started?
Similar to a Fordson.Electric was primary, air secondary.
When dug in or parked for a period of time. The Russians had a small wood stove that could be set in a trench under the tank with the stove pipe exiting out past the road wheels. The stove not only kept the engine warm but also heated the crew compartment some.
Well, that is the point exactly. Many of them DID die. With no effort from the Russian army. They may have left them running all night in some cases but the supply line got stretched too far for that to be an option.I don't care how cold it is; if your life depends on getting a motor started you're going to figure out a way to get it going.
The Germans had two big problems with their tanks: They weren't reliable enough or easy enough to repair for their crews to be able to keep them running. And they never had enough of them.
My FIL enlisted in the army right after WWII. (He would have enlisted sooner, but wasn’t old enough) Since he was fluent in German, he did his time in Germany and Austria to help the rebuilding effort and was in charge of dome ex-German soldiers. They told him that Germany lost the war because if a tank needed major repair, the German tank crew had to do the repairs themself. If an American tank needed major repair, the Americans just got themselves a brand new tank.The Germans had two big problems with their tanks: They weren't reliable enough or easy enough to repair for their crews to be able to keep them running. And they never had enough of them.
The old time loggers would do that, minus the stove. Build a fire under the belly pan and let er warm up a bit.Electric was primary, air secondary.
My father used a propane torch in a stovepipe to warm the JD350 crawler, but he caught it on fire one winter.The old time loggers would do that, minus the stove. Build a fire under the belly pan and let er warm up a bit.
A lot of German tank crews died of carbon monoxide from using Esbit stoves and bunker heaters inside of their tanks trying to stay warm.Well, that is the point exactly. Many of them DID die. With no effort from the Russian army. They may have left them running all night in some cases but the supply line got stretched too far for that to be an option.
Patton is a great movie, but it's not a documentary. (Although Omar Bradley, played by Carl Malden, was a consultant on the film.)They would blow the turret off from those cheap poor built Sherman's we had at that time. Sherman was a salmon can compared to the panzer and tigers. In fact if you pay attention to Carl Malden In Patton he tells the operators that managed to live long enough to tell it said that to him the Sherman when hit by a German tank the rivets just bounced around in there a bit like shrapnel.
I'm sure it seemed that way. In fact, the Shermans were relatively easy to repair compared to the German tanks. And the US was turning out Shermans and shipping them overseas at a rate Germany could never match.My FIL enlisted in the army right after WWII. (He would have enlisted sooner, but wasn’t old enough) Since he was fluent in German, he did his time in Germany and Austria to help the rebuilding effort and was in charge of dome ex-German soldiers. They told him that Germany lost the war because if a tank needed major repair, the German tank crew had to do the repairs themself. If an American tank needed major repair, the Americans just got themselves a brand new tank.
And they were probably right.
Oh, get off me. Starting Diesel engines in cold weather.... wtf difference does it make what they're in?Is this a TRACTOR, or FARM question? Interesting, yet out of place! Not unlike Tim Walz in a boy's room.... Post Script--"Air Start" is unspecific. Medium diesels, think locomotive size, tend to use 1 to 3 air start motors. The Largest inject HP Air directly...
My grandpa always thawed frozen water pipes with hot water.Minnesota here.
Dad was good at getting things warmed up a bit.
A 3-5 gallon pail of hot water can transfer a lot of btus for a short time. The egg washing bucket was wider and shorter, fill with hot water and sit under something for 15 minutes.
It’s good to remember those days, when I get a fuel filter gelled up or exposed pipe froze or some such, don’t need to fumble with a flame or propane torch, just a little hot water….
Paul
