yanmar 1500 fluid capacities
Status
Not open for further replies.
coolant capacity <U><s></s><B><s></s>around 1.5 gallons<e></e></B><e></e></U> &amp; mix ratio? <U><s></s><B><s></s>25% - 30% antifreeze<e></e></B><e></e></U> regular ant-freeze? <U><s></s><B><s></s>Yes <e></e></B><e></e></U>
hydro/trans oil capacity? <U><s></s>10 quarts<e></e></U> JD303 Compatible oil
engine oil? <U><s></s><B><s></s>4qts<e></e></B><e></e></U> 15/40Wt Diesel engine oil
thank you very much. <U><s></s><B><s></s>your welcome<e></e></B><e></e></U>.
I have the YM1700. Is the coolant mix the same as above for the 1500? Mine has been running hot when above 90F lately.
One quart of oil at canging puts the oil level halfwy on the dipstick on my yanmar 1500 , is this correct ? Everything I see says it takes 4 quarts.
Status
