yanmar 1500
ronofohio
This message is a reply to an archived post by JCSinGA on March 20, 2009 at 03:49:23. The original subject was "Re: yanmar 1500".
I just acquired a YM240 Yanmar today and would like to change all fluids before doing much with it. I presume it just uses standard oils and lube, but would like to make sure. It has a loader that works well. It is a 2 cy. diesel, ez start and pretty good shape except for a little rusting paint where the previous owner left it out all year long. Anyway, do you know of any website where I might get some info. Maybe a free downloadable owners manual. Appreciate any help. Thanks..Ron
Thanks. I spent some time on that site this am and got some really good info. I don't know if they still manufacture the Yanmar, but it appears that parts are readily available..Ron
jd303 fluid or equivalent utf traveler, supertech.. etc..
c rated engine oil.. etc.
I ran 30w in my 1700 which is very similar to a 240.
soundguy
Thanks Sounder. I didn"t know you had a Yanmar. From what I gather, this YN240 is kinda common. I asked the previous owner and he told me he used 15w45 Cl Rotella in the engine and 80 wt in the tranny. I"m not so sure if I want to use the 80wt. I think it is the same sump for the hydraulics too. It just makes sense to make sure I"m using that which the manufacturer recommends when I change it all. Another buddy with a 1500 asked me if mine was red or green. His is green and mine looks yellow, but that may just be red that has faded. The only serial number is on the left fender and it is 00922. Everything else on the decal is un-readable. BTW..I traded my 9n for this one because I need the loader from time to time and I just didn"t use the N enough to justify keeping up with the maintenance....Ron
your ym240 is still a fully supported machine via yanmar. It's a domestic model as are most of the 3-digit models. my 1700 on the other hand is a grey market import, and for the most part.. unsupported.
Unless there was some huge change.. your machine is a common sump deal wanting utf fluid.. not gear oil. I used to have 240 manuals as they were 'close' to my 1700.. but I ended up giving them to a fellow that had a 195 ( manual covered the 240 and 195 ).. he needed them more than I did.
any yanmar dealer can still order tons of parts for your domestic machine.
15w40 c rated is a good generic diesel oil.. etc..
soudnguy
