Yellow Project #4 301 Gasser
geok
Progress is slow on the 301 gasser. Block is cleaning up well. Still haven't gotten the head back from machine shop. Had some diesel cylinder sleeves out of yellow project #2, the 301A tree flatten father & son project. They had about .003 wear on them. I almost started to cut them down to fit the gas block. But after searching online, I found some NOS gas cylinder sleeves. So I went with them instead. Here is before and after block pictures and the diesel sleeves almost getting cut down on the lathe but didn't. Yellow project York and getting a Yanmar running again that had a seized up injection pump are keeping me side track a little.
(quoted from post at 11:57:46 09/24/22) Progress is slow on the 301 gasser. Block is cleaning up well. Still haven't gotten the head back from machine shop. Had some diesel cylinder sleeves out of yellow project #2, the 301A tree flatten father & son project. They had about .003 wear on them. I almost started to cut them down to fit the gas block. But after searching online, I found some NOS gas cylinder sleeves. So I went with them instead. Here is before and after block pictures and the diesel sleeves almost getting cut down on the lathe but didn't. Yellow project York and getting a Yanmar running again that had a seized up injection pump are keeping me side track a little.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto136552.jpg>
Chucked in the lathe like that, the sleeve is no longer round.
