So I’ve been going through a saga with my 630. Seals completely gave out on the pedestal so I finally had to tear it apart. Got everything back together. Still didn’t have great steering so went ahead and did bushings, seals and bearings in the pump. This is where I’m at now. (Copy paste from my Facebook post)
Ok. Officially at a loss on the steering for this 630. Been through and rebuilt the pedestal (all seals including vanes, and bushings). Rebuilt the pump. All new seals bearings and bushings. Filled halfway up the dipstick with Deere steering oil (AF2235R). First start was encouraging, I had one finger power steering. The longer it sat here the worse the steering got to the point that it’s basically manual steering now. Gauge shows 400psi at full lock. Flow control adjustment makes 0 difference in pressure (book says it should go up to 130psi when adjusted right) neither backing it all the way out nor running it in as far as possible make any change in the pressure reading.
The valve is as centered as I can get it. Although that’s basically pushed as far back toward the operator as it can go within its bolt holes and I just barely have left hand steering.
I set all of the backlash adjustments as close as I was able with my dial indicator. Worm end play is right on 4 thou. Helix width is as close as I can get it to 2 thou. The only adjustment I didn’t make was taking shims out between the worm and pedestal. It had 3 7 thou shims in it, so I put 3 new ones back. The wheel has nearly a quarter turn of free play in it, which is the same as it was before. I assume taking a shim out would help that, but I don’t foresee it helping the hydraulic side of things.
When I put the pedestal back together I honed the lower bushing to 2.502” like the manual says. I didn’t hone the top bushing. Again like the manual says. The pedestal went back together hard, but I attribute that to new parts and tight bushing tolerances that should wear in over time.
I did add one shim to the steering sector gear as it measured 27thou and spec was max 21, adding one shim brought it down as near as I could measure it to between 10 and 11 thou so it’s right where it should be.
I can check the cold pressure tomorrow once things cool off just to see what pressure is cold.
But I’ve run out of ideas. I set everything as close to spec as I could via the manual, but it seems like I’ve done nothing but make the steering worse. (Not that it was good to begin with).
Manual steering seems ok, it’s tough but equal in both directions so i dont think theres bind in the pedestal or shafts. I think it’s more likely just the new parts that havent worn in. I could be wrong though.
What am I missing?
It still seems pump related to me. But I guess I could be wrong. There was some wear on the fan shaft but not enough that it’s leaking oil or sucking air now that the seals have been replaced. Am I possibly doomed to taking the pump back out and either getting a rebuilt unit or having this one machined?
My only other guess is my helix width is still wrong. I set my dial indicator up like the book suggested and tried to get a reading but since this tractor has the longer steering support arm it’s difficult to move the actuating sleeve at all. I’d welcome any and all advice (or videos) on adjusting the helix width
What am I missing?
