Maxthompsonm-HT
Mt Yanmar had a loose ground cable on the battery. I tightened and cleaned that up and still no crank. When I put a voltmeter across the battery when I turn the key on I have 3-4 volts. The same if I go to the engine block. OK bad cell in the battery, replace the battery, same results. I tried jumping the starter without the ignition switch in the circuit, jumper cables to the block and starter terminal. short jumper from post on starter to solenoid. Nothing. I pulled the voltage regulator. every wire going in save the white with red is common to the case/ground. Any suggestions?
I hate to just swap parts until I have some more input.
