Hello all, new to this forum. I am in the market for a tractor/ bush hog to use at my hunting property. I went and looked at a YM2000 yesterday and have a few questions. First, the front wheels are loose, the spindle/ bearings are loose, but the nut is still super tight. The nut had a cotter pin. Second, there is a little oil leaking from what appears to be underneath the bell housing(rear main seal) if so, common, bad? Those are the two biggest issues, everything else seems to work, comes with a neat little 4ft bush hog. Or should I wait for something else, also found a YM1500 but havent looked at it and not sure its still available. Thanks for you help.
