I have a YM1401D that I use to brush hog paths around the farm. It has been leaking from the front axle pretty significantly. I really don’t have the knowledge to replace seals. I read that sometimes people add “00” semi fluid grease as a “fix” for this issue. Yesterday, I drained the old oil and my plan was to add the 00 grease as well as some Lucas power steering stop leak. I quickly realized that it’s hard to just pour the grease in the fill hole. How does one add the grease? It is pretty thick. Or should I just add a little grease and then add 90 wt gear oil? Thanks in advance!
