I've just bought a house in France and as part of the deal I negotiated that the tractor comes with it. It's a UK supplied YM1401D. I've just removed the water pump which had collapsed. I thought that I would give the tractor an overhaul, change all the fluids and grease it up. I have the operators manual for it but it doesn't cover everything such as filling and drain points.
Also,before the water pump went, I used it for a few hours. When lifting the rear hydraulic arms it would take several seconds before any movement, then they would raise slowly whilst making a horrible screeching noise. I'm guessing that the hydraulic fluid is low. I can't find the fill point to check and add more.
Paul
Paul
