Engine would blowby extreme amount of smoke after running a few minutes. Noticed bubbles coming up in radiator making me suspect head gasket or cracked cylinder. I pulled the head to further investigate. I didn't find any definitive signs that the head gasket had failed but I'm not sure that means anything. Rocking the crankshaft a bit I find that #2 piston has a lot of end play (time to go underneath). I removed number 2 rod cap to find the bearing was hammered. It looked like it wasn't getting oil.
Although there was quite a bit of bearing material transferred to the rod journal it cleaned up pretty good.
Question: should I be able to see oil pumping out of all the rod journals when I spin the motor (head and pistons removed, pan installed full of oil) number 1 rod journal is squirting pretty good.
Is there a recommended procedure to test the lubrication circuit at this stage of assembly?
I just hate to reassemble the engine without verifying that all the rod bearings will get oil.
Tim
Tim
