New here.
YM1700
I did a upper rebuild last fall, new loaded head, pistons, rings, injectors and injector pump, radiator with new over flow tank. About 5 hours on it since rebuild. Some light colored smoke at first but mostly goes away. Started overheating recently after about 30 minutes of use. No bubbles in water, no water in oil or oil in water. It will force water hard out of the overflow tank on startup, the old tank cap does not have this bib it’s sealed. I have the upgraded water pump kit installed but it’s old and seemed to feel ok at the rebuild. The old radiator was in bad shape, so I replaced it, yet with a cheaper knockoff from eBay, though it looks well built I wonder if it has the same tolerances, has anyone had issues with these? I have not retorqued the head yet so will do so, going to try a new radiator cap and the old over flow cap. Tightened the fan belt but still hot. Suspect; water pump, radiator, radiator cap and tank cap. Thoughts, or experience with those radiators or anything related appreciated. Also, I have a separate issue with the governor on high rev after pulling back on the throttle it will stay at high rev and not come back to idle right away, thinking it needs adjusting?
Thank you
YM1700
Thank you
