Hello all,
Need some help/advice regarding my Yanmar YM2000 rear 3pt hydraulic lift system.
The O’ring between the Control Valve and the Cylinder Case keeps blowing (separating).
I bought the tractor with this issue (will not pick up a weighted load). Identified the blown O’ring and replaced with Hoye part per online schematic.
The tractor ran fine for a hour or so cutting grass; however, I stop to take a break and raised the rotary cutter up and the system lost pressure (implement lowered and would not lift again).
Removed the Control Valve and found the new O’ring blown (separated).
I was thinking about removing the Relief Valve on the side of the Cylinder Case for inspection.
I can’t seem to find any info on this subject. Any help would be much appreciated.
