turnerg308-HT
I am still having issues keeping my YM2000 cool, ran it over the weekend with a 4 ft bushhog, got up to about 180 or so after 45 min work (4th gear, 18'' grass), temp showed on a temp gauge that was installed instead of the idiot light..ran it with the 1400 model tiller behind it and it got up to 190 or so..i have had the radiator flushed out, changed coolant to a 75-25 mix of water to antifreeze ratio, I cleaned the radiator with air, and sprayed the fins out with water, there are a couple of cool spots on the radiator when checking with my hand, would this indicate a blockage? the areas are pretty small, could that be an issue? Also a concern that I have is that there is a fuzzy spot (dust and oil?) on the front left corner and rear left corner of where the head gasket seals the head and the block. Is this normal? no drips, no bubbles in the radiator on a cold start, no oil in the water or vice versa. I guess its new radiator time, but if those fuzzy spots indicate a bad head gasket then is it a sound investment to spend $300 or so on a radiator and hoses?
