You've had all the right
flying belgian
diagnosis so far on my 2000 dollar Dodge Dakota so here's the latest. Couple weeks ago the brake pedal started going half way down sometimes. You could not pump them up when this happened. Now this morning the pedal goes all the way down 4 times out of 5. So NO BRAKES. What's my problem this time?
(quoted from post at 16:36:07 06/05/22) diagnosis so far on my 2000 dollar Dodge Dakota so here's the latest. Couple weeks ago the brake pedal started going half way down sometimes. You could not pump them up when this happened. Now this morning the pedal goes all the way down 4 times out of 5. So NO BRAKES. What's my problem this time?
aster cylinder?
The i/2 pedal was 1/2 of the master cylinder telling you it had a failed cup. the second failure was the second cup failing. Replace the master cylinder. Reverse bleed the system with correct brake fluid to get all particles and bad fluid out of the lines. Watch a youtube to get the idea. Normal bleeding will cause contamination to get farther into the lines and cylinders. Jim
