Z134 Alternator conversion bracket source in Canada?
BrianV_
Hi all,
The gas Massey 50 I purchased had a long-ago 10SI alternator conversion done. They continued to use the generator bracket, but used a grinder to cut a slot in the middle of the lower alternator mounting 'ear' to slide over the end of the generator bracket.
Inventive, and it clearly worked... but I have no intention of taking a grinder to a new alternator to 'make it work'.
Does anyone know of a source in Canada where I can get an alternator conversion bracket like this one:
https://www.yesterdaystractors.com/Ferguson-TO30_Alternator-Base-Bracket_GFD9309.html
or event a generic bracket like this?:
https://www.yesterdaystractors.com/2348258_Alternator-Base-Bracket-Kit-Universal_24976.htm
I can find them easily on US online stores, but the shipping to Canada is horrendous.
There's a seller on Amazon that claims to be selling part no GFD9309 (for $55!), but the picture and part number in the Amazon specifics point to DB Electrical's 'new' mount type, which is either not for a 10SI-type alternator, or is otherwise just plain wrong: https://www.dbelectrical.com/products/alternator-base-mounting-bracket-for-massey-ferguson-tractor-to30-new.html
Here's the no-longer-available kit that's similar to the YT part above - this matches the eye test for what's needed: https://www.dbelectrical.com/products/bracket-kit-1200-0503bkit-for-massey-ferguson-to30-1200-0503-to30alt12v.html
Any thoughts or suggestions?
I cannot say for sure on that tractor but every conversion I have done I was able to flip the generator bracket and use a long bolt to hold the alternator on
Same for me, I can't say with that machine but on mine I just used the original generator brackets. This is on a '64 MF35 Utility. I did replace that upper long bolt, washer and nut, this pic was taken right after the conversion and it's just something I had on hand.
