Z134 Governor Arm
I doubt the internal arm pictured should be at that angle. Should I leave it or heat it up and straighten it?
The governor was working when I pulled the engine. I did have to add a about 3/8" to the control rod to get the governor to work a few years ago and I have never been able to get the compensator spring to work.
Any insight is appreciated.
As an OLD MF mechanic I wonder if the carb rod length was set right to begin with? Sometimes it needs reset longer/shorter to correct any surging or lazy governor action.
Well I never did get the governor adjusted correctly.
Can anyone give me a idea of how much force the governor arm produces as the engine accelerates? I'm assuming the force would be very noticeable (it isn't). The governor will hold the carburetor at idle with the throttle linkage disconnected and resist accelerating with finger pressure.
Has anyone ever had issues with a new governor assembly hanging up? This has about 30 hours on it, but I don't think it ever really worked right.
On any governor, the SPRING gives the speed, and the WEIGHTS slow the system back down. The control rod LENGTH is CRITICAL for good speed control when the weights and spring balance to hold a given speed. Most carbs also have the throttle shaft/plate OFFSET so if the rod is disconnected the throttle will go WIDE OPEN.
If I recall the carb/rod moves forward for speed, and back to slow/idle. With engine OFF, and rod unhooked move hand throttle to WIDE OPEN, move carb throttle fully forward. Now adjust the rod length so the pin will enter the clevis at the lever, then LENGTHEN the clevis/rod assembly ONE TURN and install the pin. If governor control is sluggish/lazy LENGTHEN the rod another turn. If the governor wants to SURGE, then SHORTEN the rod length as needed until you get the balance you want.
Dieseltec, thank you. I'll try again, but it really seems like the governor isn't giving much feedback. It's about equal to a lawnmower engine. I think it should be some what difficult to hold the governor back at 2000 rpms.
If I adjust per the manual, it will idle (because of the foot throttle) or rev up to 2800 rpm using the hand throttle. There is no in-between.
I was able to get it to work before the rebuild by leaving the compensator spring disconnected. When I tore the engine down, the balls fell out of the governor and I found the finger on the governor shaft bent at an odd angle (away from the cover).
I'll keep you posted.
