Zenith carb
Bhunt
I have a zenith carb the model number on the tag says
0577 1AB does this have the same jets as the 9667 61 62 161 162 kit I seem to remember there was a change or two it jets then they changed it back to the original jets after farmers Complained . Am I thinking about a Marvel-Schebler It was one of them. I had all that info but when my computer crashed I lost it all. I need to order a kit but I don't want to get the wrong jets. Anyone out there remember this or have that data. This is on a 1952 SC the different model number 0577 1AB rather than 9667 or 9667A. got me stumped I don't know the reasoning behind the model number change I was thinking it was jets but I'm not sure.
Thanks Byron
Where (or why) do you buy a kit with jets? The only one I worry about is the load jet and if it isn't big enough my wire bit set will cure that problem.
(quoted from post at 02:48:11 09/29/16) Where (or why) do you buy a kit with jets? The only one I worry about is the load jet and if it isn't big enough my wire bit set will cure that problem.
How would I know if its to big or to small without knowing what it should be. Maybe a stupid question but I thought Id ask
Thanks for the response Byron
Ok from what I been able to research and find out the
Zenith; carburetor manufacture number is 9667; the OEM tractor manufacture carburetor number is 05571AB
O5771AB ZENITH CARBURETOR, MODEL 161JX7, OUTLINE NO. 9667 S, SC, SO
Case solved Hope it helps someone else
Thanks Byron
