2ruNgineer
Is it advisable to use zinc Grade 8 nuts for the head?
(quoted from post at 14:59:26 02/25/20) Is it advisable to use zinc Grade 8 nuts for the head?
(quoted from post at 11:08:33 02/26/20) Side note: cadmium plating was widely used back in the day and it left a yellow hue on the parts. Today finding a plating company that will do cad is almost impossible due to EPA regulations. Today's substitute is yellow zinc and that's what you see on the upper grade bolts. Plating imparts no strength regardless of what type it is. It's only there to reduce corrosion.
(quoted from post at 13:12:28 02/26/20) I ordered 10 studs from this site. I was trying to minimize the number of replacement studs, replacing the worst ones. My luck at pulling the old rusted ones out w/o incident has been good so far, but I'm pushing my luck. The double nut on top with PB Blaster has worked so far, but i was getting close to snapping on the last one right in the middle.
