It will be there with 120k and 10 yrs on the original fluid.moisture in the fluid
I took my 06 Impala for an oil change. They said I should change one of the power steering lines as it fails around 50,000 miles sometimes. I didn't and car had the same line on it when I sold it at 185,000. Dealers like to sell you parts and service.I've been told that I should have my brake fluid changed out on my 2014 F150.
I have 120k miles on it.
Is this really necessary. I think it's a waste of money. Am I wrong?
I thinknits there all the timeIs this statement in red below referring to something I did or said or does it appear to everyone using this website.
I'm ashing this because this is the first time I have said anything here sense the new site has started.
Thanks metal Man
Metal Man it is there on every post you look at. This is the time of year folks get “cabin fever” in anticipation of “spring fever.” Key board confrontation can run high during this stretch. About a month or so ago a fair bit of the fore mentioned was going on. The suggestion was made to increase the visibility of the “warning statement” by changing its font (print color) to red. So not to worry, thanks for joining in!Is this statement in red below referring to something I did or said or does it appear to everyone using this website.
Thanks metal Man
Thanks metal Man
I think its there all the time
Yes, good idea.I've been told that I should have my brake fluid changed out on my 2014 F150.
To properly flush the system you will need a scan tool with bidirectional controls to activate the ABS pump. To do the job as it should be done you will need a Brake fluid flush machine. There are a few vacuum and low pressure systems on the market they do not do a good job at this other than easy on the pocketbook. I am a firm believer in flushing brake fluid along with that tooled up well to perform the job.I've been told that I should have my brake fluid changed out on my 2014 F150.
hydroscopic = the fluid will mix with water, dot5 synthetic does not so the issue will be as you stated water will collect in spots of the brake system. Either way water is an issue. On the black fluid its a reaction to metal most all the time I see this is when aluminum calipers are used.Yes, good idea.
Unless your vehicle has new, synthetic brake fluid (it doesn't) the brake fluid is hydroscopic and will attract water which will collect in the lowest point of the system, e.g., calipers and wheel cylinders.
I had the brake fluid in my 2017 vehicle changed a couple of years ago.
No, I did not say that it is "necessary."
