jimg.allentown
Are EV discussions now a prohibited topic? Or just the ones that go sideways?
I believe you will need to ask your question through the "Contact Us" button. YT Support (Chris) has posted numerous times he does not get involved in that part of things.Are EV discussions now a prohibited topic? Or just the ones that go sideways?
Before the format change, there was a warning about absolutely no politics, religion , etc. discussions. Is that gone or still around somewhere?Correct Jim. I closed the tread because it had several issues headed in an unfriendly direction.
Good point. It is when you start a thread but not above the posting window where it also needs to be. I will mention this to the team.Before the format change, there was a warning about absolutely no politics, religion , etc. discussions. Is that gone or still around somewhere?
Hi! Good call out, you should now notice that I have added the same warning to the reply box below. Thank you for your input!Before the format change, there was a warning about absolutely no politics, religion , etc. discussions. Is that gone or still around somewhere?
Thank you!Hi! Good call out, you should now notice that I have added the same warning to the reply box below. Thank you for your input!
HAHA, you are safe! Just a general warning/notice. We had it in other places on the site and it was a good suggestion to add hereLol! I just noticed that and thought: Huh, is that for Me? What did I do?
Then I realized it was probably a general warning.
Thanks.
John, neither Justin nor I could recreate this on desktop or phone. We might be looking in the wrong place. You said "Main Page" so we presumed it was the top level "Post" button that appears when you've clicked Forums. Is that where you weren't seeing the warning?I now see the warning in the reply box.
Actually it is below the reply box so I could type a reply and hit post reply without seeing the warning if I did not scroll down quite far enough.
But I can not find it any where on the main page when I try to start a new thread.
I notice the warning has turned red sometime in the last couple hours. Should be pretty hard to miss it now.
ChrisJohn, neither Justin nor I could recreate this on desktop or phone. We might be looking in the wrong place. You said "Main Page" so we presumed it was the top level "Post" button that appears when you've clicked Forums. Is that where you weren't seeing the warning?
