Dillsburg 560D
Good afternoon, i have replaced the entire engine, left and right harnesses. Also the rear harness with new light switch in the dash. New voltage regulator installed also. have everything wired per instructions and the schematics. the problem i am having is engine starts fine it just won't turn off untill i either cut the power at the fuel shut off solenoid by unplugging or if i tap lightly on the voltage regulator. What am i missing here? I installed a new resistor near the coil as well. I'm sure i am missing something or have something wired incorrectly. Thank you in advance for any help. I forgot to add that if i don't rev the engine it will shut off with the key. When the generator starts charging it will not shut off with the key. It has to be back feeding somewhere. This also has electronic ignition on it.
